Freezes on Model to Sheet?
New problem arose today I have a part finished everything seems to be working fine until I go to use the model to sheet function. After I use it I select my options and during processing Viacad becomes unresponsive. Any ideas or work a rounds?
ViaCAD Pro V9, build 1104, Windows 7 professional 64 bit service pack 1, Dell T1600 desktop, Intel Xeon CPU E31245 @ 3.30 GHz, 32 meg ram, Graphics 2x Nvidia Quadro 600 Hi, I have the same problem, I cannot print working drawings of my model, when I use model to sheet ViaCAD just becomes unresponsive, did you have any luck sorting this out? I can use model to sheet only on a relatively simple model, anything starting to get more complex causes this problem.
>>ViaCAD Pro V9, build 1104 I would recommend getting the latest build. Quite a few corrections since 1104. You can access the build from the Help : Current Version menu item from within ViaCAD Pro. Tim
