CNW
#1 Posted : Monday, November 9, 2015 11:19:12 PM(UTC)
CNW
It seems I am missing something as to how the Model to Sheet function works. I have checked the forum for tutorials etc. but not found anything to answer my question as of yet. I am trying to highlight a single part, have it generate a sheet view and then dimension that view to original scale. It sizes images down to fit sheet and scales accordingly. The only "fix" I have found to date is to select the complete screen and scale it up to the correct size for dimensions. This is a great tool but would like to figure out how to best use it and hoping for some tutorial or additional information. Thank you in advance for any assistance offered.
Craig
#2 Posted : Tuesday, November 24, 2015 7:26:38 AM(UTC)
Craig
The dimension scale will always be correct, it does not matter how small the model is scaled down to fit the sheet, the size does not change, only the scale does (hope that makes some kind of sense)?
