Tim how can we select mesh like my example ? (inside of object) ...you know we don't have ambiguity window.
Jean-Francois Jacques attached the following image(s):
(48kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
>>can we select mesh like my example ? (inside of object Box select each of the four face vertixes. >>you know we don't have ambiguity window. We plan to update the selection of vertices, edges and faces. Tim
Originally Posted by: Tim Olson >>can we select mesh like my example ? (inside of object Box select each of the four face vertixes.
Box select ..what do you mean,(Tool Box selection)? I used Select Edge for each vertex.
Thanks: 30 times Was thanked: 42 time(s) in 36 post(s)
Drag the selection tool over each of the four vertices, do it individually then you stand less chance of picking up any vertices behind the ones you want to select. Box select is draging the pointer over an area that you want to select, but you often pick up vertices behind the ones you want so I box select vertices individually or in groups if there is nothing behind them.
