hatched or filled objects
Hello, I have the following problem. When I hatch or fill an object, I can not move it afterwards. It kind of gets stuck on one spot. After a few tries, it might move one or 2 times, then again gets stuck. CAn anyone help with this? What am I doing wrong? Thanks!
Try moving the objects that define the hatch. The hatch position is defined by these objects. Use Edit :Remove Links to delete the dependency. Tim
