Originally Posted by: mitchb Take a look at your Preferences -> User Interface. If "Use WorkPlane Coordinates in Data Entry" is checked, uncheck it. That fixed it for me.
I reported this as a bug to Tim a couple of weeks ago. At least, I think this is a bug, maybe my understanding of work planes needs some help.
Mitch
Thanks Mitch but mine was unchecked.
There is a definite issue with the workplane in V9, I did a side by side comparison with V8 for them and both programs operated totally different as far as the workplane is concerned.
Why would they do that, V8 and V9 are basically the same program so they should react the same, I think they are in denial as this bug requires a tear down as it is at the heart of the program.
Anytime a CAD system forgets which way is up..........you know you have serious problems.
I do feel that this is a long standing issue in the CAD/modelling community, xyz is a fixed system but you see some jokers using y as the vertical axis!!!!
To me they are thinking like machinists, if you are milling a part on a vertical milling machine you are always working on the x/y plane, if you need to machine another face on the same part you rotate the part and then you are still working in the x/y plane.
For me computer modelling and CAD is a different scenario, you are not moving the part when you go into front view, you are moving the world so the z axis remains in the vertical orientation and if you work on the front face you are working in the x/z axis.
I understand why they do it but I think it is causing a conflict, the gripper stays global, the part goes local but the input figure remains global, confusion rules.
