points generated by PowerPack verification
Thanks: 7 times Was thanked: 12 time(s) in 11 post(s)
Hi is there a way of making/Forcing the points generated by Verifications in PowerPack to Generate on to a separate Verification point Layer? If not this would be very useful for doing a mass delete after you have sorting out any errors. Regards Brian
Hi Brian You could set the work layer prior to using the command. Tim
Hi Tim
i have tried this by setting up a points layer and making that the live layer then running the gap analysis but they are still generated on the layer for the problem objects.
i believe i have done what you said please see screen shot
i tried this on a second attempt and it worked.
i am finding also if not all lines are in the same direction tim it also generates gaps is this correct?
Best Regards
Brian S
Edited by user Friday, January 29, 2016 7:38:52 AM(UTC)
thefro attached the following image(s):
(164kb) downloaded 20 time(s). You cannot view/download attachments. Try to login or register.
Hi Brian >>i tried this on a second attempt and it worked. Concept Explorer was not updating until you clicked the Ok button in the dialog box. I corrected this for 1186 so you see it before you hit Ok. >>i am finding also if not all lines are in the same direction tim it also generates gaps is this correct? Direction should not show as a gap. If you have an example where direction is showing up as a gap could you send me the file? Thanks Tim
Hi Tim
Is there a better explanation for the use of the tool? on the site?
if it is used by dragging across curves it produces a different result to selecting curves as individuals in a chain the latter generates the points. the explanation on the site is a little vague on the correct use. I'm afraid i have corrected the problem so all curves face i the same direction.
if you look at the example i posted gaps are shown along the bottom of the drawing this is where the lines meet i was surprised these where generated.
i find there are inconsistent results depending on how i select elements in the drawing.
Brian
Edited by user Friday, January 29, 2016 2:27:58 PM(UTC)
LMS third Break coach v2 (Test).sfx
(989kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
A gap is where a curve does not start or end at the start or end of another curve.
If a line starts or ends somewhere along another curve that is not the start or end, that is considered a gap.
In the attached image, the red line will produce a gap.
The tool is usually used in conjunction with checking that a profile is closed for extrusion/lathe/sweep into a solid. ACIS wants an unambiguous closed region.
Edited by user Friday, January 29, 2016 2:40:24 PM(UTC)
(22kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Hi Tim I had assumed this was the case with the joins but was still surprise things are generated differently in the way i selected the curves? i find when using the Fillet two lines tool it generates a curve that is slightly offset by a very small amount i have been picking these up with the above tool. not sure why some generate correctly and others do not? If i can narrow down what is happening i will let you Know i have noticed this happening before in previous builds but have been manually correcting them and not said anything assuming it was me. Best regards and thank you again for all your help. Brian
