Suggestions
woodworking tool suggestion
Thanks: 22 times Was thanked: 8 time(s) in 8 post(s)
Hi I have a suggestion for two simple tools for wood working: mortis and tenon Pocket hole / dowel thru bolt / screw this would give your woodworking package even more appeal and speed for production shops like mine. Thanks JB
1 user thanked jbskaggs for this useful post.
I'll add these to the potential list of woodworking features. I think the pocket hole could be derived quickly from our through hole by two points feature.
(72kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
how does the two point through hole work?
Originally Posted by: jbskaggs how does the two point through hole work?
Select Simple hole
Select By Two Points
Select Face
Select hole location
Select two points for hole direction
Perhaps the Pocket Hole would
Select Pocket Hole
Specify angle (i.e. 15 degrees)
Select Face
Pocket holes set up should probably have these settings: number holes- cursor placement could snap to a end point or mid point? But most my connections have two pocket holes 1/2" from edge with a spacing of 2" on a 2x4 hole spacing- screw dia / hole dia- material thickness- this would be a simple calc to determine angle of pocket hole BOM add of screw size and count? JB
BTW a standard pocket hole has a 3/8" counter bore of approximately 1" to 3/4" then it has bore of 1/8" that travels thru the centerline of the perpendicular plane.
So when i enter my settings I get my hole backwards.
Here is a pic where I am trying to get it to work. you can see my pocket hole though it looks correct- it does not face the proper edge and the angle is wrong.
jbskaggs attached the following image(s):
(134kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
Ok I figured out how to place the x, y orientation of pocket hole. NOw though when I choose my two points I need to the angle of the drill. I need my first point aligned with back edge but also above it on the z-axis sO I can achieve that 15 degree / 20 degree angle.
Thanks: 103 times Was thanked: 18 time(s) in 14 post(s)
JB – I'm going to second your suggestion for both the Pocket Screw / Dowel and Mortise-and-Tenon tool. These would make my work much easier as well. Thanks.
Originally Posted by: jbskaggs Hi I have a suggestion for two simple tools for wood working: mortis and tenon Pocket hole / dowel thru bolt / screw this would give your woodworking package even more appeal and speed for production shops like mine. Thanks JB
Originally Posted by: jbskaggs Hi I have a suggestion for two simple tools for wood working: mortis and tenon JB
Hi JB – do you have a method that you'd be willing to share, for how you create Mortise and tenon joints?
Suggestions
