will the "Join Curve" tool
join two curves/line segments with a gap present?? if not, given the tool's name, does anyone have any ideas/thoughts on why a "gaps detected in curves error" is appearing after only selecting the tool and the interpolate spline shown in red?? the instructions in the user's guide seem pretty straight forward.................
Art
artesmith@earthlink.net Art Smith attached the following image(s):
(75kb) downloaded 20 time(s). You cannot view/download attachments. Try to login or register.
It will display that error if the boundary curves don't form a closed loop.
Is it possibly a selection order issue? The first curves you select are the closed boundary curves. Then you pick the guide curve.
In example below green curves are boundary and blue is guide.
If that is not the issue, could you post the boundary and guide curve file?
Edited by user Tuesday, February 16, 2016 1:38:59 PM(UTC)
coverGuide.sfx
(32kb) downloaded 6 time(s). Tim Olson attached the following image(s):
(106kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Tim-
after completely redrawing the geometry, neither the
Split Surface tool or the
Guide Surface Cover tool are behaving as expected. the
Split Surface tool is squawking about coincident points between the split curve and the boundary of the surface; error or feature?? the
Guide Surface Cover tool now likes the closed curve input first (ie: the joined halves of two ellipses projected onto the surface),
BUT it now sends
TWO errors without regard to if one of straight green lines is selected as a guide or the spline is selected as the guide. first error is:
cannot recognize a circuit and the second error message that appears on clearing the first:
Invalid wireframe for cover surface . see attached image.
"post" how & where, the current file is 130Mb. I can copy the file and delete the "assumed" unrelated layers to get something smaller. my internet provider limits me to sending files ≤20Mb.......
Art
(96kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
>> "post" how & where, the current file is 130Mb. Hi Art Let's see if we can get just the curves used in the command. 1. Select only the curves you are using to create the cover with guide surfaces. 2. Select : Edit Copy 3. File : New 4. In the new drawing pick Edit : Paste 5. Save As new File. Once you save the file, which should be very small, add this file as an attachment to a forum Post. On the left side of the reply is an option for "Attach files to this post" Tim
Tim-
file attached
Art
artesmith@earthlink.net File Attachment(s):
much smaller file for fault isolation.sfx
(51kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
more observations:
Art
(82kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
reference: http://forum.punchcad.co....aspx?g=posts&t=7768 Art
(49kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
reference :
Edited by user Wednesday, February 24, 2016 2:44:01 PM(UTC)
(57kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
Hi Art
In the example file you uploaded, I'm not sure what curves you are using for the boundary and what curves are guides. If this is still an issue would it be possible to provide an example that only has the boundary and guide curves?
If you are looking for some more info on Covers, I have some additional resources:
Covering PDF Cover Video Tim
Edited by user Thursday, February 25, 2016 3:11:54 PM(UTC)
Tim-
here's the requested file and a "program" to identify all the players......
Art
Guide Cover Surface fault isolation example 02-26-16.sfx
(28kb) downloaded 7 time(s). Art Smith attached the following image(s):
(58kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Hi Art
The Cover with Guides fails for this shape with the ACIS error message "Guide Curve projects outside circuit in advanced covering". The guide curve needs to project to a unique position within the boundary curves but cannot due to the convexity of the curves. So we cannot use a Cover with Guide with this geometry.
How about a skin surface? I segmented the projected ellipse and made a skin surface which is attached.
Edited by user Friday, February 26, 2016 2:40:42 PM(UTC)
skin.sfx
(33kb) downloaded 6 time(s). Tim Olson attached the following image(s):
(138kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Tim-
thanks. in spite of very public rumors and newspapers articles to the contrary, after going on three weeks (and two undocumented constraints & this TBD), it now appears the old guy hasn't completely lost it after all.............
ACIS "bug" or "undocumented feature" ??
or ACIS functions were never intended to work with concave boundary curves??
how about convex boundary curves?? or is the current tool only good for planar boundary curves?
as for two skin surfaces, I'll have to think about it. the "leading edge" as a minimum has to have a radius and after thirty seconds of thought I'm not sure how to go about that. two skin surfaces I'm guessing will yield a line (ie: sharp edge)...........
Art
with curves on concave surfaces out, both alternate formulations have hit road blocks.
1.) is there any way to adjust/demand the Guide Cover Surface" tool observe both the supplied boundary curve and guide curve??
2.) are there setting(s) I'm missing on Skin/Loft tools that would eliminate the current bellows like results...............?
Art
(85kb) downloaded 6 time(s). guide cover surface - alternate formulations 2of 2.jpg
(55kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
