Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
I'm trying to stitch a group of surfaces into a solid. There are about 1450 surfaces though. How can I tell where the problem is ?
I tried uploading but am getting an error uploading the file...
solidtooldesigns attached the following image(s):
(34kb) downloaded 13 time(s). You cannot view/download attachments. Try to login or register.
There is a detailed log file that is created in your preferences folder called healing.log. It can tell you if the geometry was good going in. If you have PowerPack, something I find helpful is to stitch the surfaces together with Closed Volume Required turned off. Then use the PowerPack: Show Free Edges to isolate the edges that were not shared. Sounds like you hit the maximum size for attachments. Tim
Ahh okay. I had a feeling the Powerpack would have what I'm looking for. The file I tried to upload was less than 7mb. Weird.
