Antoine
#1 Posted : Wednesday, February 24, 2016 4:18:30 AM(UTC)
Antoine
Switzerland
Was thanked: 32 time(s) in 26 post(s)
Hello Tim,
How can I weld that blue surface on the green volume please?
Thank you.
Antoine
velo.sfx (146kb) downloaded 12 time(s).
Antoine attached the following image(s):
Capture d’écran 2016-02-24 à 11.14.25.png (236kb) downloaded 10 time(s).
Antoine
#2 Posted : Wednesday, February 24, 2016 4:26:45 AM(UTC)
Antoine
Switzerland
There is the solution to convert all surfaces, then weld it all with the tool: Stitch.
But I would like a simple solution, if it exists.
Capture d’écran 2016-02-24 à 11.24.08.png (187kb) downloaded 12 time(s).
#3 Posted : Wednesday, February 24, 2016 11:34:19 AM(UTC)
Hi Antoine
Do you need the previous underlying blend? It looks like they share the same space. If not, remove the blend with deep select and then do a Solid Boolean Add with the surface.
Edited by user Wednesday, February 24, 2016 12:04:35 PM(UTC)  | Reason: Not specified
