G2Art
#1 Posted : Wednesday, April 6, 2016 10:06:09 AM(UTC)
G2Art
Extruded solids can be easily created from profiles consisting of several curves (a couple of lines and a couple of arcs, for example).
However, when the time comes to replace the profile consisting of some other curves, when I shift-click to select all of the new curves, after I select the first one the process comes to an abrupt stop.
I've tried grouping the curves in the new profile but that did not work. I have turned off "enable auto resolve". No good.
Replace profile seems to work only if the replacement profile is a polygon drawn with the Polygon tool.
I'm running Shark FX v9 1162 on a Mac Pro.
In the example in the picture, I'm trying to replace the orange profile with the blue one. It does not work.
Any suggestions would be appreciated. Thanks.
Mark
Edited by user Wednesday, April 6, 2016 10:09:08 AM(UTC)  | Reason: Not specified
G2Art attached the following image(s):
Screen Shot 2016-04-06 at 8.22.38 AM.jpg (50kb) downloaded 8 time(s).
