Dyn_Metalworks
#1 Posted : Tuesday, May 10, 2016 4:14:52 PM(UTC)
Dyn_Metalworks
While drawing house plans, if I add a door then delete it there is a gap in the wall left. Or if I move a wall the cross hatches screw up. I have to restart my computer to get VC to fix the issues. But, then any new changes it happen again.
#2 Posted : Tuesday, May 10, 2016 4:18:36 PM(UTC)
Hello
What build of ViaCAD are you using?
Are you using Mac or PC what OS?
Check to make sure you are using the latest version. Goto file menu Help ->current version.
Dyn_Metalworks
#3 Posted : Tuesday, May 10, 2016 4:42:01 PM(UTC)
Dyn_Metalworks
VC 2D/3D V9, Build 1184
Windows 10
#4 Posted : Tuesday, May 10, 2016 5:07:46 PM(UTC)
Does VC freezes up and you restart it to fix the problems you described? Does it show any error messages or just become unresponsive? Is it only one file or can you repeat on different files?
Dyn_Metalworks
#5 Posted : Tuesday, May 10, 2016 8:18:12 PM(UTC)
Dyn_Metalworks
It doesn't freeze, but restarting the OS does fix the issues. But, as soon as I change another object it messes up. No error messages and it does it on all files. These files worked fine last week.
Dyn_Metalworks
#6 Posted : Tuesday, May 10, 2016 9:26:46 PM(UTC)
Dyn_Metalworks
So I uninstalled VC and reinstalled it. Same problem as before and now when I start a new drawing VC stops running and crashes.
