Hi does anyone no how I fix the Dimension witness line length? See attached working Drawing
also how do i attach a pdf?
3 FLOOR PLAN.pdf
(3,044kb) downloaded 26 time(s). You cannot view/download attachments. Try to login or register.
ok worked outhow to attach the pdf
Thanks: 185 times Was thanked: 159 time(s) in 109 post(s)
The Inspector is the place to control Dimension Properties.
I'm not sure about the witness lines, but this is the place to start.
(47kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: L. Banasky The Inspector is the place to control Dimension Properties. I'm not sure about the witness lines, but this is the place to start. Larry
Hi L.Banasky thanks for your reply.
I try to keep all my dimensions the same length see attached
Can I create my owner dimension arrow?
Edited by user Wednesday, May 18, 2016 6:43:07 AM(UTC)
277 23-NOVEMBER-2011 SHEET 2.pdf
(256kb) downloaded 13 time(s). You cannot view/download attachments. Try to login or register.
I don't know if you can create your own, but there are plenty to choose from.
(45kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Thanks L.Banasky for your help. Thats pretty much made up my mind about the program, it's great in some areas just lacks that little bit extra control that "I" like, it's close to what I wanted, but just not quite there yet. I not sure if I'll continue with it at this stage Thanks 18 years experience in the Building Design & Drafting Architectural. I use Autosketch " Old Drafix" with House Rocket 18 Years. Chief Architect 12 Years Revit 4 Years Archicad 4 years Turbocad "Windows" 4 years Drafsight 1 year ViaCad testing TurbocadMac Looking at? Trying to replace Autosketch ?
Originally Posted by: Trendstyle Design Thanks L.Banasky for your help. Thats pretty much made up my mind about the program, it's great in some areas just lacks that little bit extra control that "I" like, it's close to what I wanted, but just not quite there yet. I not sure if I'll continue with it at this stage Thanks 18 years experience in the Building Design & Drafting Architectural. I use Autosketch " Old Drafix" with House Rocket 18 Years. Chief Architect 12 Years Revit 4 Years Archicad 4 years Turbocad "Windows" 4 years Drafsight 1 year ViaCad testing TurbocadMac Looking at? Trying to replace Autosketch ?
I am not sure there was anymore control in auto sketch . Maybe you can explain what you want to control and we can help you.
Originally Posted by: Trendstyle Design Hi does anyone no how I fix the Dimension witness line length? See attached working Drawing also how do i attach a pdf?
Hello
In the Inspector, dimension properties you can control the witness lines
Edited by user Wednesday, May 18, 2016 7:08:29 PM(UTC)
(46kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Yes manually each time but I'm talking about automatically for rows of dimensions see attached
Trendstyle Design attached the following image(s):
Capture DIMENSION WITNESS LINES EXTEND THE SAME AMOUNT WITHOUT EDITING EACH ONE.PNG
(82kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
Hopefully this will explain what I'm trying to do.
Capture DIMENSION WITNESS LINES EXTEND THE SAME AMOUNT WITHOUT.pdf
(1,642kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
see attached jpeg
(292kb) downloaded 18 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 42 times Was thanked: 69 time(s) in 51 post(s)
Hi
Trendstyle Design The problem as I see it is your selection of the endpoint for your dimension.
If you look at this picture, if I click on the endpoints of the line at the bottom I get long witness lines, but if I click on the bottom and drag up to a common intersect position they are all maintained the same...so you need to maintain a consistent reference position for your dims, essentially translating the vertical drops into a horizontal equivalent, by plotting the intersections.
I hope this makes sense, but I did this sketch with no mods to tolerances or otherwise.
Using SharkFX, but it should be the same in ViaCAD
Mike
PS Is this your normal drawing style? I only ask, and not being rude, as it looks a tad "cluttered" to me, but I'm no architect. :)
Edited by user Thursday, May 19, 2016 1:29:59 AM(UTC)
(36kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
macOS Sequoia - MacBook M1 Max 64GB 2TB SSD & external display - SharkCAD Pro v14.1.0 build 1654 macOS Tahoe - v16 beta
Hi again,
Trendstyle Design ,
OK, I played with the tolerances and values, and this is pretty clean, and I think follows what you're trying to do with the annotated picture.
Settings as per boxes, and I thought the DIN setting seemed cleaner than ANSI
Hope this helps, but I learnt something from your query, so thanks for the question. :)
Mike
(41kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: 24c Hi Trendstyle Design The problem as I see it is your selection of the endpoint for your dimension. If you look at this picture, if I click on the endpoints of the line at the bottom I get long witness lines, but if I click on the bottom and drag up to a common intersect position they are all maintained the same...so you need to maintain a consistent reference position for your dims, essentially translating the vertical drops into a horizontal equivalent, by plotting the intersections. I hope this makes sense, but I did this sketch with no mods to tolerances or otherwise. Using SharkFX, but it should be the same in ViaCAD Mike PS Is this your normal drawing style? I only ask, and not being rude, as it looks a tad "cluttered" to me, but I'm no architect. :)
Hi Mike Thanks for your imput.
Yes this is pretty much it. The one I have shown as an example is from the building company I'm doing work for. But they are all very similar through out WA.
We don't use large format prints that often (Mainly because the Local shires & Builders prefer A3 size sheets) Some even specifically requesting the smaller format. So this means Cramped Cluttered Drawings with notes wherever you can fit them and lots of sheets. This is why I need to keep the Witness lines at a set distance :-).
Thanks again Joe
PS I agree about them being cluttered.
Edited by user Thursday, May 19, 2016 7:39:33 AM(UTC)
Thanks: 60 times Was thanked: 46 time(s) in 32 post(s)
Hi there
On the version I am using there are some additional settings in the standards manager that may be useful.
Hope this helps
(273kb) downloaded 26 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: MaiFy Hi there On the version I am using there are some additional settings in the standards manager that may be useful. Hope this helps
Thanks I will try that and see if ViaCad is the same
Edited by user Thursday, May 19, 2016 5:57:17 PM(UTC)
| Reason: spelling
Just tried it could not get it to work still the same issue.
Hi Trendstyle Design . Did my workaround not work? I was able to get the witness lines were a lot shorter, and I did away with the very long ones too by creating intersection points. for the dimension start & end positions. Mike
Originally Posted by: 24c Hi Trendstyle Design . Did my workaround not work? I was able to get the witness lines were a lot shorter, and I did away with the very long ones too by creating intersection points. for the dimension start & end positions. Mike
That will work but it will take too long. I'll keep testing it for a better way.
thanks
Joe
