JPChristou
#1 Posted : Monday, June 6, 2016 1:28:10 PM(UTC)
JPChristou
Hello
I've been trying to design vase types with flat surfaces for 3D printing and although I've set the resolution on my model to a "superfine" setting I'm still resulting with a mulifacatted surface instead of a smooth surface as desired.
Is this smooth cylindrical surface achievable? And if so...how?
I would appreciated any and all help on these matters.
Claus
#2 Posted : Monday, June 6, 2016 10:42:54 PM(UTC)
Claus
Denmark
Hi, you set the resolution when you export to stl for your 3d printer. I normally put 1 mm as edge length value, then hit the update button and then export.
Claus
thanks 1 user thanked Claus for this useful post.
JPChristou on 6/7/2016(UTC)
horst.w
#3 Posted : Tuesday, June 7, 2016 1:29:57 PM(UTC)
horst.w
You do not need to hollow the objects body when you want to print it in 3D.
Every slicer-program (I'm using Simplify3D) has the "vase" or "spiral"-mode. This will say, your print is execute with only 1 perimeter (real diameter = 1 x ExtrusionWidth) and the number of BottomLayers you have choosen.
Otherwise you can set as follow:
Perimeter = 1
BottomLayer = 5 to 8 e.g.
Infill = no
TopLayer = no
This solution is better to print, because a given wall has always 2 sides, an outerside and an innerside. And the diameter of this wall is minimum twice the "ExtrusionWidth".
best regards
Horst, GER
thanks 2 users thanked horst.w for this useful post.
GARLIC on 6/7/2016(UTC), JPChristou on 6/7/2016(UTC)
Claus
#4 Posted : Tuesday, June 7, 2016 1:43:08 PM(UTC)
Claus
Denmark
Horst, if you are referring to my answer, edge length is just the size of the edge of the triangles exported, nothing to do with wall thickness.
Claus
