can't get the area function to work it takes all the points then does not provide data when I hit the enter key
Thanks: 30 times Was thanked: 42 time(s) in 36 post(s)
It should provide the data without hitting enter, if I select an object and then use the area function a box pops up immediately.
Originally Posted by: Craig It should provide the data without hitting enter, if I select an object and then use the area function a box pops up immediately.
Im not getting the box pop up
Ill upload the new build today, although Im a bit nervous since Im in the middle of a big job
You can always uninstall and reinstall the old build which is a pain but if I remember right 1184 was not a good build, I think I had a lot of trouble with it and when I went to 1186 it was like night and day.
Originally Posted by: Craig You can always uninstall and reinstall the old build which is a pain but if I remember right 1184 was not a good build, I think I had a lot of trouble with it and when I went to 1186 it was like night and day.
I'm going around in circles trying to fond how to get the latest build. Is says to click on the help button. That says I have the latest build which is 1184!
How do you contact support to order the good version?
Originally Posted by: michaelclark Originally Posted by: Craig You can always uninstall and reinstall the old build which is a pain but if I remember right 1184 was not a good build, I think I had a lot of trouble with it and when I went to 1186 it was like night and day.
5th thread down in the news and announcements section.
Edited by user Thursday, June 16, 2016 1:35:03 AM(UTC)
