evakyl40
#1 Posted : Sunday, July 10, 2016 6:39:25 PM(UTC)
evakyl40
When I try exporting my drawing to a DWG, it causes my dimensions and Notes to become distorted (pointing in wrong direction and a mess).
Any ideas how to fix it? I'm using ViaCad V9.
Regards,
Kyle
#2 Posted : Sunday, July 10, 2016 6:42:07 PM(UTC)
Originally Posted by: evakyl40 Go to Quoted Post
Regards,
Kyle
Hello Kyle
What are you opening the dwg file with after exporting?
evakyl40
#3 Posted : Sunday, July 10, 2016 6:48:10 PM(UTC)
evakyl40
I am opening it with ViaCad V9 to see if everything looked fine. That's when i noticed the dimension issue. I am going to try opening it in Draftsight tomorrow morning.
Kyle
evakyl40
#4 Posted : Monday, July 11, 2016 4:11:51 AM(UTC)
evakyl40
The misplaced dimensions were there when I opened in Draftsight. I was able to simply move them back and now I'm fine. My drawings aren't too complicated, so it's not that much of an issue now. I will just draw in ViaCad, export DWG, open and modify in Draftsight.
Regards,
Kyle
#5 Posted : Monday, July 11, 2016 10:08:29 AM(UTC)
FYI, I corrected several DWG dimension issues around build 1204 related to text placement. If you post an example, I'll see if it has been corrected for service pack 3.
