Kartoffel
#1 Posted : Wednesday, August 3, 2016 12:08:47 AM(UTC)
Kartoffel
Was thanked: 5 time(s) in 5 post(s)
Hello,
I made a test with my new ViaCAD 9 pro + PP Installation. I created some Quad-Mesh-Blocks and "subdivided" them three times. Then I wanted to make a solid of the whole thing with right mouse click Change Object to: solid.
I then get a message that this Option is limited to 3000 facettes?
On an other PC, I have a Testversion of Shark FX installed without Powerpack an there I get the same behavior.
But in Shark FX, there is the SubD to NURB - Function/Button to make a solid.
So, for me, the subdivision functionality is useless, when I can't make solids.
I first bought 2D/3D, now pro with pp. Obviously, now I should buy pp-pro?
Markus
#2 Posted : Wednesday, August 3, 2016 3:06:32 PM(UTC)
Hi Markus
Shark FX and PowerPack Pro license the IW SubD To NURB kernel for mesh to solids. Based on the kernel, It adds new tools to convert mesh into solids. Note the IW kernel is 64 bit only.
The Edit : Change Object to Solid uses the ACIS license to convert meshes to solids which is limited. ACIS recently added a new kernel component to support meshes, but it is an additional cost and the initial releases are not as advanced as the IW kernel for mesh conversion. I'm actively keeping an eye on it...
If you need advanced mesh to solid that would an option. EvoSoft has created upgrade link for those who want pp pro from pp that reflects your pp purchase. This url has some example mesh conversions with pp-pro. It also bumps your build into a ViaCAD 64 build.
Edited by user Wednesday, August 3, 2016 4:43:26 PM(UTC)  | Reason: Not specified
Kartoffel
#3 Posted : Thursday, August 4, 2016 2:27:13 AM(UTC)
Kartoffel
Hello Tim,
thank you for the informations..
I assume, when upgrading to pp-pro (64bit), I also have to reinstall VC9pro > 64bit? At the moment, I use the german VC9pro+pp bundle. Do I have to use then the english versions, because pp-pro and the 64bit VC9pro version is only available in english?
Markus
#4 Posted : Thursday, August 4, 2016 3:07:55 AM(UTC)
Hello Markus,
Yes, it will keep your 32 bit build plus add a 64 bit build. I can private email you with steps to convert a ENG version to DE as long as you have access to a v9 German install. You will need to copy some folders from the DE build to the ENG build.
FYI, we are getting closer to a V10 beta where all builds will be 64 bit.
