Solid Modeling
Rounding causes poly to disappear
Created a square using the polygon tool. Use revolve 360 degrees to form a ring with 4 sides. Attempted to round the outside edge -- rounding the edge caused some polygons on the rounded edge to disappear. I thought this was a display error but when I export to OBJ the polys are not there. They could be getting flipped on the rounding attempt. I could undo set a higher (looser) bevel and the rounded edge would show. If I then change the round to a smaller number, the missing polys came back.
It might be a faceting issue. Try changing the resolution (Edit: Change Resolution) of the lathed solid to include Precision. This will refacetted the solid using different settings.
If that is not the issue can you post the lathed solid?
Edited by user Monday, August 22, 2016 11:55:58 AM(UTC)
Solid Modeling
