Historie of the construction is not stored
Thanks: 5 times Was thanked: 26 time(s) in 22 post(s)
Hi at all,
I'm using ViaCad 9 Prof German Version.
When I store an object all historie is lost when reopen it next time.
In <Presetting> the box "Delete GoBack when store" is
NOT checked on - the picture shows it only to demonstrate what I mean.
But I tried also "checked on" because the translation of this menue-point may be fault. No difference, the GoBack-historie ist not stored when I close the window - checked or unchecked.
What is going wrong there?
Greetings Horst, GER
[img=
]PreSettings[/img]
Hello Horst Yes, I can confirm here that the undo stack gets clears when the program closes on V9, no matter what settings are picked in preferences. Regards Jason
Thanks for the information. Horst
The setting in the preferences I believe its intent is just to clear the undo stack or not when a save is done while working on a file. When you close a file and reopen the undo stack is cleared. Thanks Jason
