#1 Posted : Sunday, September 11, 2016 5:27:26 PM(UTC)
The Select Same tool is used to select entities based on shape, color, font, layer, type attributes.
Video demonstration of Select Same in PowerPack
https://youtu.be/ddGn8freY50
Are there other attributes designers would find useful for the Select Same tool?
rokoko
#2 Posted : Monday, September 12, 2016 2:35:10 PM(UTC)
rokoko
interesting method - isn't it much the same as "select mask"? maybe both methods could be merged.
perhaps a bug: when selecting "same entity type", locked objects are included in that selection. this can cause funny results when batch changing the whole selection in inspector. every object becomes locked.
after a click in empty space the selection appears "unselected", but is still active!
Edited by user Monday, September 12, 2016 2:36:20 PM(UTC)  | Reason: Not specified
#3 Posted : Monday, September 12, 2016 2:41:55 PM(UTC)
The issue I have with Select Mask is that the large dialog box seems cumbersome and disruptive to the work flow.
Yes, this is a bug. Locked objects should not be included in the selection set. Fixing now...
Checking....
Thanks for the feedback!
rokoko
#4 Posted : Monday, September 12, 2016 2:46:47 PM(UTC)
rokoko
lasso select seems to select locked as well. with lasso select a selected object do not show inspector attributes immediately. a separate click in inspector is needed
btw, in context menu an "unlock" command would be helpful
Edited by user Monday, September 12, 2016 2:49:07 PM(UTC)  | Reason: Not specified
Antoine
#5 Posted : Tuesday, September 13, 2016 7:51:28 AM(UTC)
Antoine
Switzerland
Was thanked: 32 time(s) in 26 post(s)
Fantastic!!!
Thank you Tim
Very useful
Antoine
#6 Posted : Tuesday, September 13, 2016 10:24:00 AM(UTC)
Fixed in next build (1304)
