gensmenger
#1 Posted : Friday, September 23, 2016 9:30:39 AM(UTC)
gensmenger
VIACAD PRO is so important to my work that I would not to upgrade MacOS, if not ready.
Are there still issues that must be resolved before the green light to upgrade?
#2 Posted : Saturday, September 24, 2016 3:54:17 PM(UTC)
Encore QA is testing a build of ViaCAD 9 now as a service pack update. It does have a correction for Window tab issue in Sierra that was appearing in preview builds.
I just sent and email to Encore Tech support to see if they have had any reports.
gensmenger on 9/27/2016(UTC)
#3 Posted : Monday, September 26, 2016 10:08:40 AM(UTC)
FYI, so far no issues have been reported to Tech Support regarding Sierra.
neotericsimian
#4 Posted : Wednesday, September 28, 2016 9:45:08 AM(UTC)
neotericsimian
I recently upgraded to MacOS Sierra and ViaCAD Pro (build 1184) has stopped working. I can start the program but can not open an existing drawing or start a new one, it just sits there until I force quit.
Has anybody else experienced this problem and do you have a solution?
Oscar Erickson
FOLLOW-UP: I just learned a work-around. If I open ViaCAD and THEN try to open a file (or create a new file) it hangs at "updating curve display list" and I have to force quit.
BUT if I double click on a .vcp file to start ViaCAD it will open the file and I can then open and close other files. I haven't done extensive testing on that but it worked several times.
Edited by user Wednesday, September 28, 2016 8:05:34 PM(UTC)  | Reason: Found a work-around to the problem
#5 Posted : Wednesday, September 28, 2016 10:11:53 AM(UTC)
Hello Oscar
I would recommend contacting Encore tech support. I'll forward your post over to them as well and see if they have heard of this before.
