Art
#1 Posted : Monday, October 3, 2016 8:30:44 AM(UTC)
Art
I am not sure this is a Shark Problem or my system. I cannot shift-select. I do not have the problem with other programs. Occasionally, if I keep on doing it I can get all selected.
Is there anybody else having this problem?
Art
Shark FX 9.0.8 1168
Mac 10.11.6
#2 Posted : Monday, October 3, 2016 4:06:41 PM(UTC)
Was thanked: 164 time(s) in 101 post(s)
I'm having a lot of problems with select and unselect too...
Art
#3 Posted : Monday, October 3, 2016 4:50:22 PM(UTC)
Art
Not to be insensitive, but that is good to hear. Are you on a similar Mac system?
Art
Shark FX 9.0.8 1168
Mac 10.11.6
mitchb
#4 Posted : Monday, October 3, 2016 6:19:21 PM(UTC)
mitchb
Was thanked: 65 time(s) in 33 post(s)
I have the same problem. This is associated with the ambiguity popup menu. Holding the shift key to select items works until the ambiguity popup appears and a selection is made from that. The next selection will de-select all the previous selections. After making the selection from the popup, release the shift key and hold it again to continue selecting. At first, I thought my shift key was defective. The prompt window will give you a clue as to whether the next selection will add to your selections or de-select all. When the selection tool is selected there are three lines of instructions, pressing the shift key changes it to two lines, as long as there are two lines you will add to the selections. After selecting from the popup menu, the prompt window reverts back to the original three lines. At this point release the shift key and re-engage it to continue.
Mitch
Art
#5 Posted : Sunday, October 9, 2016 4:18:00 PM(UTC)
Art
So nobody else thinks this is a problem?
Does everyone have this problem?
Is it a Mac problem?
Tim, Can you help?
Art
Shark FX 9.0.8
Mac 10.11.6
horst.w
#6 Posted : Monday, October 10, 2016 12:36:57 PM(UTC)
horst.w
ViaCAD V 9 Pro Win 64 works fine.
H.
Art
#7 Posted : Monday, October 10, 2016 8:45:45 PM(UTC)
Art
Other Mac people having this problem?
Art
Art
#8 Posted : Friday, November 4, 2016 11:17:07 AM(UTC)
Art
Solved in Shark FX 9.1.13 (build 1216)
