JimKal
#1 Posted : Thursday, December 29, 2016 3:32:45 AM(UTC)
JimKal
Hi
I am new to ViaCAD 2D/3D and am wondering why the straight line tool will no draw a horizontal line on a grid line. If you remove the grid it works ok and it will also work on an area which is not on a grid line. It also works on 45 degree angles. When you select the single line tool and position the cursor on a grid point and click it, the x appears there and then when you select another point on the grid and click it, an x appears but no line. Is there a setting which tells this control not to work on the grid?? I have the latest version of Windows10 on my computer.
JimK
theo52
#2 Posted : Thursday, December 29, 2016 8:31:25 AM(UTC)
theo52
Netherlands
Hi Jim,
Try to click on "window" and select the snap tool and select grid
Edited by user Thursday, December 29, 2016 8:33:09 AM(UTC)  | Reason: Not specified
theo52 attached the following image(s):
#3 Posted : Friday, December 30, 2016 3:55:03 PM(UTC)
Thanks Theo
I did as you suggested but I still have the same problem. I tried playing a'round with the buttons and the unchecked 3 items without success.
Maybe I should download and reinstall the program and try again!!
#4 Posted : Friday, December 30, 2016 4:17:48 PM(UTC)
...perhaps a solution problem?
I tried it - all is normal (Via9 Pro Win7 Pro)
Horst
