Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
Tim and Team, is it possible to add a menu to Power Pack Pro so that those of us who use 3D printers different than those listed can set up volume requirements for our printers in PowerPack? I use primarily Deltas (Okay, I only use deltas and half my FFD clients do as well) and i also have clients that are using different build volumes and being to create a volume would be useful. Thanks Michael
SharkCAD Pro v10 w/ PowerPack Pro Lenovo D20 2x E5620 w/ 64GB RAM, Nvidia 1060 OS: Windows 10 Pro x64 MM0MSU
Was thanked: 523 time(s) in 358 post(s)
Hi Michael The 3D Printer definition are located in a text file in the Environ folder called print3D.ini. To add a printer, edit the file and add the following information. Values are in inches. *************** Name= FlashForge_Creator Length= 8.9 Width= 5.7 Height= 5.9 Layer= 0.00393700787 Tim
