daleroe
#1 Posted : Thursday, February 9, 2017 2:43:44 PM(UTC)
daleroe
When I double click to open a SFX file, while the file is opening, a text file "commandline.txt" is created in the folder containing the SFX file. If I open the SFX file within Shark it doesn't create the text file.
The contents of the file is:
original command line "C:\Program
-background
My searches show that it's used in some gaming circumstances. Is Shark creating this or my operation system? Can I turn it off?
Anything you can tell me about it would be appreciated.
Thank you
-dale
Edited by user Thursday, February 9, 2017 2:46:33 PM(UTC)  | Reason: edit description
HP Z800 Dual Xeon 5690 3.46Ghz 64GB
nVidia Quadro 6000 6GB
Win pro 7-64
SharkCAD Pro v10.0.0 B1354
Shark FX v9.0.4 B1162
#2 Posted : Thursday, February 9, 2017 3:17:44 PM(UTC)
Hi Dale
Shark is creating the "command line.txt" file. It was used to check command line arguments passed into Shark. In later builds it was disabled it.
daleroe
#3 Posted : Thursday, February 9, 2017 4:08:07 PM(UTC)
daleroe
Thanks Tim.
Some booleans are taking hours to complete, does "-background" effect the performance? Likewise, can I change the commandline.txt contents like the gamers and improve performance? It appears like I'm only using a small amount of memory and only one processor core, is that normal?
Win pro 7-64
