don.key
#1 Posted : Wednesday, March 8, 2017 4:10:45 PM(UTC)
don.key
I have a ViaCad 10 Pro license, used it with Yosemite without problems and just upgraded to Sierra. Unfortunately ViaCad does not work properly now if more then one display is connected. There are many symptoms, I cannot select or 'pull out' tools from tool pallet, when I by some luck manage it then moving those sub-pallets drops them off into different place on screen then the one I actually dropped them off to etc.
This seems like ViaCad software issue, all other apps work fine.
Setup:
iMac with Nvidia card and Nvidia GFX drivers 367.15.10.35f01
OSX 10.12.3
ViaCad Pro 10.0.0 Build 1317
And I am not trying to use ViaCad across the displays, everything stays on main display.
Any ideas how this can be solved?
#2 Posted : Wednesday, March 8, 2017 5:33:17 PM(UTC)
I have done some testing with multiple monitors. Some configurations and resolutions may cause problems.
Try placing ViaCAD on the main monitor with the external monitor configured above or to the right.
If the above works but you are trying to take advantage of a larger external monitor set the external to main with the smaller monitor above or to the right.
If none of that works, send me your VCPPrefs.ini file located in the /Users/<user>/Library/Application Support/com.encore.viacadprov10 folder.
This file contains info on your monitors and resolutions.
don.key
#3 Posted : Monday, March 27, 2017 6:06:03 AM(UTC)
don.key
Unfortunately problem still exists, Tim, are there any news on this and when fix can be expected? As it stands now VC10 is not usable on systems with multiple displays under Sierra.
Edited by user Monday, March 27, 2017 6:07:48 AM(UTC)  | Reason: Not specified
