horst.w
#1 Posted : Sunday, March 26, 2017 2:10:45 AM(UTC)
horst.w
@ Tim Olson
Hi Tim,
I would realize this topic
http://forum.punchcad.co...sts&t=8417#post32141
in ViaCAD 10 but the program doesn't offer this option.
On this way I tried out some possibilities with the Align-command and found out that the two last options -Spaced Vertical and Spaced Horizontal - of the pull down menue do not work. Clicking on the both options they jump back to the first option - Left Sides - .
The two options are not available or is it a bug?
VCP 10 Build 1330 Win 7 Pro
Best Regards
horst.w
BillB
#2 Posted : Monday, March 27, 2017 3:36:59 AM(UTC)
BillB
The two spaced align command will only work with more than two objects. They basically equalise the distance between objects.
Bill Bedford
Viacad Pro 11 (11417)
OS X 10.13.6
#3 Posted : Monday, March 27, 2017 9:34:58 AM(UTC)
Was thanked: 503 time(s) in 353 post(s)
I added an alert dialog box if less then three are selected last night. (build 1335) .
horst.w
#4 Posted : Monday, March 27, 2017 10:17:52 AM(UTC)
horst.w
.... thanks all together!
H.
PS works fine!
Edited by user Monday, March 27, 2017 10:22:42 AM(UTC)  | Reason: Not specified
#5 Posted : Tuesday, March 28, 2017 12:53:01 PM(UTC)
FYI, some minor improvements to this in 1335 uploaded today.
JeffT
#6 Posted : Wednesday, December 6, 2017 10:50:58 PM(UTC)
JeffT
I'm having the same problem with spacing. I have 6 objects selected that I want to vertically space and the the menu selection defaults to align left no matter what I try. I've tried it with different objects with 3 or more items with the same results. I can manually space equally using grids, but it would be a time saver to be able to use the tool command. All other align commands work except the vertical and horizontal space. I'm using ViaCad 2d/3d v10 Mac build 1354 if that helps. Any advice would be appreciated.
Thanks.
digitalphaser
#7 Posted : Thursday, December 7, 2017 3:56:42 AM(UTC)
digitalphaser
It often happens when objects are a copy or instance of another object. Try breaking the link(select all objects and Edit-->Remove Links). Often it helps. But you will lose the inheritance properties of the object.
thanks 1 user thanked digitalphaser for this useful post.
JeffT on 12/7/2017(UTC)
#8 Posted : Thursday, December 7, 2017 12:58:24 PM(UTC)
Thanks.
Hello Jeff
What are the objects you are trying, groups, 2d, 3d , circles, etc.
I see the spaced vertical and spaced horizontal are not behaving as expected here either.
