@ Tim Olson
Hi Tim,
I would realize this topic
http://forum.punchcad.co...sts&t=8417#post32141 in ViaCAD 10 but the program doesn't offer this option.
On this way I tried out some possibilities with the Align-command and found out that the two last options -Spaced Vertical and Spaced Horizontal - of the pull down menue do not work. Clicking on the both options they jump back to the first option - Left Sides - .
The two options are not available or is it a bug?
VCP 10 Build 1330 Win 7 Pro
Best Regards
horst.w
(86kb) downloaded 41 time(s). You cannot view/download attachments. Try to login or register.
The two spaced align command will only work with more than two objects. They basically equalise the distance between objects.
Bill Bedford Viacad Pro 11 (11417) OS X 10.13.6
I added an alert dialog box if less then three are selected last night. (build 1335) .
.... thanks all together!
H.
PS works fine!
Edited by user Monday, March 27, 2017 10:22:42 AM(UTC)
FYI, some minor improvements to this in 1335 uploaded today. Tim
I'm having the same problem with spacing. I have 6 objects selected that I want to vertically space and the the menu selection defaults to align left no matter what I try. I've tried it with different objects with 3 or more items with the same results. I can manually space equally using grids, but it would be a time saver to be able to use the tool command. All other align commands work except the vertical and horizontal space. I'm using ViaCad 2d/3d v10 Mac build 1354 if that helps. Any advice would be appreciated. Thanks.
It often happens when objects are a copy or instance of another object. Try breaking the link(select all objects and Edit-->Remove Links). Often it helps. But you will lose the inheritance properties of the object.
1 user thanked digitalphaser for this useful post.
Originally Posted by: JeffT I'm having the same problem with spacing. I have 6 objects selected that I want to vertically space and the the menu selection defaults to align left no matter what I try. I've tried it with different objects with 3 or more items with the same results. I can manually space equally using grids, but it would be a time saver to be able to use the tool command. All other align commands work except the vertical and horizontal space. I'm using ViaCad 2d/3d v10 Mac build 1354 if that helps. Any advice would be appreciated. Thanks.
Hello Jeff
What are the objects you are trying, groups, 2d, 3d , circles, etc.
I see the spaced vertical and spaced horizontal are not behaving as expected here either.
