Shark FX9: how to rotate part axis
as above. I have the Y axis inverted for some reason. Im close to finishing the work, but need to send to be made but cannot reset the axis or rotate part. Please help Thanks Rick
Rick Can you use the rotate tool instead of the gripper. What errors are you getting? What geometry is it? Is it references by curves. Maybe make a copy and try removing links only on the copy and see if you can rotate it then. Or even export as a sat and reimport into a new file and try rotating then. Regards Jason
Hello Jason tried the rotate tall and get the message : unable to rebuild feature from clues: fillet_1340251 (part_882455 Layer = layer 1) then the software crashes. (running a power mac book pro, with nothing running in the background other than safari. Try the axis tool and soft crashes too Just tried to save as SAT and re imported it, it worked to some extent, Ive got the part the right way up, so thanks for that. but when I click on Views such as top, side, they are off still so no idea whats going on Thanks you for the help Jason
