Combining B Curves and Lines
Is there a method for combining multiple Bezier curves or lines into a single "group" before I can extrude it.
I know once I see it, it will be obvious, but I don't see how to do it. None of the videos extrude from a complex part (ie a combination ). I have don a Bezier curve that closes on itself in one action, it extrudes fine.
Help and thanks from a newbie :)
holddown.vc3
(13kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 185 times Was thanked: 159 time(s) in 109 post(s)
Probably not the best way, but it will work.
http://www.screencast.com/t/JYoE6M9uM Larry
Thanks - That help!! the concept of LINES vs CURVES (Object types) was not apparent to me. as anyone seen a write-up on the concepts around Object types and the impacts on usage.
