Andrew Gray
#1 Posted : Friday, May 12, 2017 10:23:19 PM(UTC)
Andrew Gray
Hi All
see attached, I'm trying to use the pipe tool t0 draw a steel section along a line
the line is 2deg rotated, is it poss to rotate the axis so the steel section is at 2deg?
Thanks Andrew
Andrew Gray attached the following image(s):
rotate axis.JPG (21kb) downloaded 6 time(s).
rotate axis2.JPG (26kb) downloaded 6 time(s).
rotate axis3.JPG (59kb) downloaded 7 time(s).
MaiFy
#2 Posted : Saturday, May 13, 2017 12:27:38 AM(UTC)
MaiFy
Hi Andrew
Is this what you are trying to do, or something else?
Andrew Gray
#3 Posted : Saturday, May 13, 2017 4:51:11 AM(UTC)
Andrew Gray
Yes I can simply use the gripper and rotate 2deg but I was using the pipe tool. I tried to get the section rotated within the command
horst.w
#4 Posted : Saturday, May 13, 2017 1:46:20 PM(UTC)
horst.w
The pipe tool ask for a path curve. That may be also a straight line which is turned for x degrees.
Hope that is what you mean.
horst.w, GER
Andrew Gray
#5 Posted : Saturday, May 13, 2017 10:17:39 PM(UTC)
Andrew Gray
Basically want to put the square section along the line but rotate it 2 degrees
horst.w
#6 Posted : Sunday, May 14, 2017 12:13:54 AM(UTC)
horst.w
... for this I don't see a solution with the pipe tool but you can reach it with the One Rail Sweep Solid. While the rotated square pipe must be hollowed I think it is much more complex than to use the gripper.
