Hi All
I'm looking for a workflow to align a inserted profile (steel section) with my construction lines
see attached, align the steel section blue direction with the green line
Andrew
Andrew Gray attached the following image(s):
(78kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
I'd put a two-point block on the line, use magnet to put the profile on the face with the alignment you want, adjust with move and rotate if it's needed.
Thanks, All solved with rotate three point tool Andrew
