Solid Modeling
v10.0.0 Build 1335 solid model representation Problem
v10.0.0 Build 1335 is representing solids in a very curious manner; see attached image. is there something funny going on or was something reset with the download of the build and I haven't found it ??? I've been through the complete wireframe/true solid representation menu to no avail............
Art Smith
artesmith@earthlink.net Edited by user Wednesday, May 17, 2017 7:54:08 AM(UTC)
(33kb) downloaded 18 time(s). You cannot view/download attachments. Try to login or register.
more data on my suspect solid problem
Art
artesmith@earthlink.net Art Smith attached the following image(s):
(47kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
Hi Art Does the part check ok using Verify : Check Object? Also does it give a proper volume with Verify : Volume. Tim
Tim-
"check object" reports questionable; see attached image. verify attributes look "reasonable"; an opinion on "proper" would take some work as the shape is a NACA 0024 with a non-standard truncated trailing edge.....
the perimeter (ie: the shape to extrude) has been checked with the PowerPack "Show Gaps" tool and indicates good.
Art Smith
(53kb) downloaded 15 time(s). You cannot view/download attachments. Try to login or register.
starting from scratch on a clean layer with clean profiles from AeroPack fixed whatever was ailing it. strange the profile checked out fine with current PowerPack verification tools.....
Art Smith
Solid Modeling
