issue with moving multiple faces with gripper
i tried to move 4 faces (which have been selected by deep select tool) simultaneously with the gripper.
when entering a distance after a first move with the gripper, the new value is added to the first move. this is a bit unexpected, because a data entry after a move should set the entire distance just as if only one face is selected.
build 1337 mac
(27kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
It's the same with Win 7, but using the "normal" Select-tool the movements are not added. Regards horst.w, GER
