Originally Posted by: posh.de OGL is processed by the GPU if the driver supports OGL, which more or less all drivers of dedicated video cards do... more or less reliable, thus Radeons (optimized for speed with games) are not recommended for the Windows platform.
which means the software graphics engine has to use a framework that the video driver supports, thus making sure there is a match is a good thing. however, if Geforce and Quadro both support same level of OGL in the driver then i am not really sure why one card would be better than the other other than hardware spec.
i am looking at nvidia GTX 700 series, it's more of a gaming card then a CAD card, but will still kick butt supporting most CAD programs, and costs less than Quadro. take a look at this comparison (
http://www.videocardbenchmark.n...gpu.php?gpu=Quadro+K4000). however, its known fact that for heavy 3D and rendering, you want a Quadro or FirePro card. another metric might be video outputs, do you need or want DisplayPort or Thunderbolt? is HDMI or DVI ok? etc.
back to OP's Q. i believe the answer is yes, since this CAD uses OGL and Quadro supports OGL (verify versions of OGL supported), the system should be able to exploit the benefits of OGL being processed in the video card for near instant screen updates.
and some tidbit info, some of the GTX cards can be mod'd so they act much like a Quadro or Tesla card (with limitations).
