How to setup the default for hidden control points. In Viadcad Pro 10
Somehow i turned on visible control points 3d and 2d for objects created. I cannot turn off the Visible control points except when the object is selected. Is there a way to setup VCPro 10 to control the behavior globally and not per object selected? Is there a keyboard shortcut that turns this on and off? any help would be appreciated thanks
Originally Posted by: tedems Somehow i turned on visible control points 3d and 2d for objects created. I cannot turn off the Visible control points except when the object is selected. Is there a way to setup VCPro 10 to control the behavior globally and not per object selected? Is there a keyboard shortcut that turns this on and off? any help would be appreciated thanks
Hello
Ctrl+D toggles control points It is also in the edit menu --> show points
deselect all objects (nothing should be selected) and uncheck menu -> edit -> show points to get the default setting.
