Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Is there a way to convert a top level layer to a sub layer and move it under a different top level layer? For example, I started on an airplane design and I created layers for various sections like fuselage, wings, horizontal stab, vertical stab, etc. As I started adding more details I decided it would be better to make those layers sub layers under a new top level layer called airframe. Is there an easy way to do this? Thanks. XMack
1 user thanked xMack for this useful post.
Thanks: 339 times Was thanked: 216 time(s) in 149 post(s)
This is a very good idea. For layers have i more ideas like Sort in alphabetical order and Layername = Feature (Part)-Name and Multirename and Multidelete, Hiding Layers permanently (show not when use the command "Show all") etc.
Edited by user Saturday, June 24, 2017 5:30:12 AM(UTC)
Yes xMack, a very good idea : When I import files I need to move some imported sublayers to other levels. Today I recreate the layers and move the elements to them... Problem : it's impossible to move many elements with history to another layer at once ! It seems that the links loose reference during movement :-( Often ends up into a big mess.
Thanks: 231 times Was thanked: 183 time(s) in 110 post(s)
Originally Posted by: Guest Yes xMack, a very good idea : When I import files I need to move some imported sublayers to other levels. Today I recreate the layers and move the elements to them... Problem : it's impossible to move many elements with history to another layer at once ! It seems that the links loose reference during movement :-( Often ends up into a big mess.
That was me, your guest !
