Art
#1 Posted : Friday, June 23, 2017 7:53:49 PM(UTC)
Art
If you select an item and perform a 3 point rotate, you can then input a number and it will snap to that angle. If you do the same thing to a group, it does not move.
I have attached a file, the bottom item is a group.
Art
Mac 10.12.5
SharkCad Pro 10 1335
Rotating Groups.sfx (117kb) downloaded 6 time(s).
rokoko
#2 Posted : Saturday, June 24, 2017 3:19:54 AM(UTC)
rokoko
i can confirm that problem in build 1342 Mac beta. seems to be a bug
Art
#3 Posted : Tuesday, June 27, 2017 8:49:28 AM(UTC)
Art
Thanks, Any PC Users have the same problem?
Art
Mac 10.12.5
horst.w
#4 Posted : Wednesday, June 28, 2017 1:22:57 AM(UTC)
horst.w
ViaCAD 10 Pro for Win (7 Pro) works fine with the grouped 3-p-rotation, but a similar problem extists with groups (tested with Polar Duplicated cylinders). It is not possible to pull up the body of the group, the pull-up-tool knows only single surfaces (here: top of a cylinder - 1 of 8) - no reflexion to the group. The same - also multi choice is not possible with the pull-up-tool. (Info-text: Selected curves can move region)
Best regards
horst.w, GER
