Fred
#1 Posted : Wednesday, August 16, 2017 8:44:07 PM(UTC)
Fred
I can see how we can edit co-ordinates of a polygon using Inspector. This is quite unwieldy, but better than nothing.
Am wondering if I have missed a way to do it with the mouse, or at least to select, (or even just see the highlighted point during Inspector fiddling)?
Extra question:
Can we edit a particular segment during it's life as a polygon, eg. change the segment from a line to a curve, spline etc? (or do we just explode and fiddle with the pieces, then rejoin using 'From curves polygon)
Cheers!
BillB
#2 Posted : Thursday, August 17, 2017 2:10:38 AM(UTC)
BillB
You turn on 'Edit->Show Points', select one of the small squares and move it with the gripper.
Edited by user Thursday, August 17, 2017 2:11:32 AM(UTC)  | Reason: Not specified
Bill Bedford
Viacad Pro 11 (11417)
OS X 10.13.6
thanks 1 user thanked BillB for this useful post.
Fred on 8/17/2017(UTC)
Fred
#3 Posted : Thursday, August 17, 2017 7:20:49 AM(UTC)
Fred
OK! Now I get it- the step I was missing was to use window selection to activate the point. (I was expecting to be able to click on the point to activate.) Now I know this everything will be much easier.
Thankyou heaps : )
