Export to PDF produces fonts issues
Hello,
ViaCAD 1341 / macOS 10.12.6 ;
Setting up a print job with 2 draw views produces this bizarre result, despite all the fonts being used for dimensions being installed and activated on the computer.
Is this a known bug, are there reliable workarounds?
Thank you,
Regards,
thmrtnz
Untitled 1.pdf
(174kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
I have found that there is a low resolution picture embedded inside the pdf, see attached files.
Is this regular? Do I need to clean the document with a vector editing tool? Is it an issue with Apple PDF engine?
Regards,
thmrtnz
(1,311kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
thmrtnz Can you post that ViaCAD file? Regards Jason
Hello Jason,
Sure, see attached file.
Thank you,
thmrtnz
Untitled 1.vcp
(345kb) downloaded 14 time(s). You cannot view/download attachments. Try to login or register.
Here is pdf printed from ViaCAD to cutepdf print driver on Windows 10 system.
ViaCAD Pro _Untitled 1.pdf
(17kb) downloaded 15 time(s). You cannot view/download attachments. Try to login or register.
Thank you. There must be a problem with my Apple pdf printer.
Originally Posted by: thmrtnz Thank you. There must be a problem with my Apple pdf printer.
It works OK with my OS 12.6
Untitled%201.pdf
(84kb) downloaded 15 time(s). You cannot view/download attachments. Try to login or register.
Bill Bedford Viacad Pro 11 (11417) OS X 10.13.6
Thank you. Definitively something is wrong here. I'll fix it!
Well, I have reinstalled macOS and I still get this result. I don't get it.
Hello, Using another CAD package, I get perfect results. I'm puzzled.
There are two copies of your drawings in your ViaCAD file. Preview shows these as pages 1 and 3 of the pdf I made. Whatever you are using to view the pdf is overlaying the two versions of the draw.
I understand it works quite right with the right type view selected in Properties panel of a given Layer View.
Here are two files attached to explain.
add.: and here is the extracted background, from Phong type view.
Edited by user Wednesday, August 23, 2017 7:41:04 AM(UTC)
copy.pdf
(162kb) downloaded 7 time(s). copy.vcp
(50kb) downloaded 5 time(s). thmrtnz attached the following image(s):
(57kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
This is a screen shot of the page layout of your file using A1 paper
PastedGraphic-1.pdf
(113kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Thank you. I know there are three sheets but it is not related to my corrupted output. If I define the Page layout to print cleanly only one sheet, and the Layer View is still phong type rendering, there's a bitmap/raster background. I have clean install a second time macOS Sierra 10.12.6 and the issue persist. Ah, I don't get it.
