I'm having a hatching problem again; SharkCAD Pro build 1341. used the
N-Sided Polygon tool to draw the cross section shown in the attached image in the hopes of minimizing exposure to the hatching tool to NO avail. the PowerPack
Verify Show Gaps tool shows/finds no gaps as expected.... hatching was working the last time I used it but don't remember the build number. is anyone else having hatching problems??
Art
[email protected] Art Smith attached the following image(s):
(16kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Hello Art
If its a polygon it already has a fill, its just turned off. If you select the polygon and go to inspector object properties data tab, you can show the fill, and change it to whatever color/pattern you want in the fill menu.
(43kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
Jason-
thanks!! didn't realize there was a polygon fill switch; out clevered myself........ it's back to the tried and true "group" approach.
Art
[email protected]
