Solid Modeling
Shark Pro v.10 1341 - bug intersection
Thanks: 2 times Was thanked: 32 time(s) in 26 post(s)
Hello Tim and co
there is a bug with the intersection option.
Thank you
Edited by user Wednesday, October 25, 2017 2:14:24 AM(UTC)
Antoine attached the following image(s):
(137kb) downloaded 21 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 233 times Was thanked: 184 time(s) in 111 post(s)
Originally Posted by: Antoine it's not clear?
The pipe is clearly blocked...
(c'est bouché!)
Seems to be true for all pipes where the internal diameter intersects.
Bill Bedford Viacad Pro 11 (11417) OS X 10.13.6
>>Seems to be true for all pipes where the internal diameter intersects. Yes this is a limit to the tool. If the path self intersects, it cannot subtract the inside. Same limit for a circular section. Tim
Tim?
if it is a limitation, then do not propose the shell function in intersections mode.
This gives confusion.
Thank you.
Antoine
Edited by user Tuesday, October 31, 2017 4:51:10 AM(UTC)
Shelling will fail as well because it is not a valid part. (ambiguous inside/outside surfaces). Because of the ambiguity, I also don't think it is manufacturable.
I did notice that if the sweep profile contained the inside profile, it will sweep. This avoids the subtract or shell post steps. I'll look into this.
Edited by user Tuesday, October 31, 2017 12:20:37 PM(UTC)
Was thanked: 47 time(s) in 23 post(s)
You could try to cut away and repair the self-intersecting part and shell it afterwards
Solid Modeling
