la mouche
#1 Posted : Wednesday, December 7, 2011 3:55:53 AM(UTC)
la mouche
Hello Tim,
This discussion has already been said several times :)
Shark may be even more extraordinary in modeling, if you could enhance the editing on surfaces.
Do not you think?
Indeed, it is impossible now to transform an surfaces worked.
http://screencast.com/t/VMw7xTTV
Many thanks.
Antoine
Capture d™©cran 2011-12-07 10.54.50.png (103kb) downloaded 8 time(s).
Tem
#2 Posted : Thursday, December 8, 2011 1:47:08 PM(UTC)
Tem
That should not be happening, the last surface created should at least remain and not disappear as your screencast shows.
Something is obviously wrong. I think the expectation is that when the surface feature that the last surface feature (blend?) is based on is modified then the following result would be an update to the blend surface feature.
It would be very nice to have this associativity issue fixed.:-)
