Art Smith
#1 Posted : Saturday, November 18, 2017 2:15:07 PM(UTC)
Art Smith
cutting a solid cylinder with the "cut section" tool yields the vast majority of the time an ellipse, or probably more correctly a perimeter that looks like an ellipse. how do I establish a line tangent to a resulting perimeter that looks like an ellipse and a co-planer circle ??
if there's not currently a way to do it directly, is there a way to extract the major and minor axis from a resulting perimeter that looks like an ellipse??
Art
[email protected]
murray
#2 Posted : Saturday, November 18, 2017 4:59:54 PM(UTC)
murray
I did this the other day, scaled ellipses are recognised as splines so I wanted to define the figure as ellipse. Apply a bounding box to the spline, the major and minor axes can be measured from the edges of the box.
Art Smith on 11/18/2017(UTC)
Art Smith
#3 Posted : Saturday, November 18, 2017 7:03:08 PM(UTC)
Art Smith
Murray-
thanks, very clever!! hadn't thought of a bounding box approach. "of course" it took a few more steps because the ellipse isn't aligned with the current work plane.... fortunately verify also provides max & min principle axis so a box can be constructed to enable replacing the perimeter that looks like an ellipse with a real ellipse. convoluted, but it gets there.....
Art
[email protected]
#4 Posted : Monday, November 20, 2017 11:02:41 AM(UTC)
Was thanked: 164 time(s) in 101 post(s)
[email protected]
Hello Art,
I'm sorry to say : a scaled ellipse is not an ellipse any more.
And it's been like this since the time of Pythagorus, or maybe earlier...
I know because I did this mistake before.
Try other ways...
JL
Art Smith
#5 Posted : Monday, November 20, 2017 2:38:16 PM(UTC)
Art Smith
JL-
yes, but it's plenty good enough for estimating "clearance" center lines routing tubes.... it was a CAD mechanization question, not geometry.
Art
[email protected]
RF-00 up and back exhaust.JPG (42kb) downloaded 6 time(s).
#6 Posted : Monday, November 20, 2017 4:29:46 PM(UTC)
I understand now.
Great routing job Art !
JL
Art Smith
#7 Posted : Monday, November 20, 2017 10:19:00 PM(UTC)
Art Smith
JL-
thanks! the postulated structural tubes had a huge impact on the degree of difficulty and the quality of the eventual solution. the triangular tubes pushed the exhaust aft AND pushed the point of maximum frontal area aft. without the structure "in the way", normally tube #3 defines maximum width. frontal area and taper ratio are really BIG deals in everything that influences aero drag......
Art
[email protected]
