Solid Modeling
Problems with the Skin Solid Funktion
Hi guy´s sorry for my english I´ll give my best :-)
I want to create a Solid from two polygons with different Z height wich I have created from arc & lines there
is no way to get an even distribution of the surface around the edges.
I tried several ways like changing the direction of the acrs and lines or convert arcs to beziers.
Also i tried to use differnt paramters to create the skin solid in the Options menue.
I have attched some images to show yo my problem.
AndreasH attached the following image(s):
(83kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 633 times Was thanked: 103 time(s) in 65 post(s)
could you upload the basic geometry / boundary curves ? for some testing ... regards G.
This is the basic geometry / Units Metric mm
Andy
basicTest.vcp
(8kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
I would add the radius blends as features afterward !
Thank you !
This comes very close with elipytical Fillet, but how can i prevent the undersite edge to get rounded with.?
(103kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Well done ... Press the option key (Mac) within the elliptical blend tool Turn OFF 'automatic chaining' and select just the edge you want Jol
Sorry Jol ... unchecking this option doesnt´t help.
I tried the variable blend linear funktion, but it doesnt´t follow the inner arc exactly .
Andy
(56kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Hello Andy
Is this what you are looking for see attached file.
basicTest2mod.vcp
(3,843kb) downloaded 1 time(s). jdi000 attached the following image(s):
(102kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Hi Jason !
Thank you !
The corners are looking good, but it seems that the surfaces along are concave or am I wrong ?
I need flat ( plain ) surfaces along the sides
Andy
Edited by user Tuesday, January 2, 2018 5:11:52 PM(UTC)
Then - best way is to build all your surfaces manually as 4 sided patches, then stitch it together into a solid ! Jol
1 user thanked Jolyon for this useful post.
Andy
Here is another try see if this is what you wanted.
basicTest2mod2.vcp
(3,940kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
If I understood correctly, then for corners I would use a Skin Surface tool Arc to Point. Then stitching to solid.
skinning.vcp
(336kb) downloaded 5 time(s). digitalphaser attached the following image(s):
(94kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked digitalphaser for this useful post.
Thing about geometry is - there are infinite possibilities ! You will likely have to try several approaches to get the answer you want Experience helps greatly with this You're doing great !
You could try the loft surface command with 0 bulge to give flat surfaces. In the corners, you need points however. so you loft between the curve and a point.
1 user thanked rockyroad_us for this useful post.
Thank you all for your great tips. I got it now with the tip from digitalphaser, thats exactly the best result for me. There are a lot of functions left, that I have to learn. greetings from germany Andy
Solid Modeling
