mfontana
#1 Posted : Friday, January 19, 2018 11:44:46 AM(UTC)
mfontana
I need to offset several different holes. How do I:
A: Select only them?
B: Move them by a specified amount in the X and Y coordinates?
#2 Posted : Friday, January 19, 2018 12:03:09 PM(UTC)
Hello
This depends on how the holes were created?
Did you use the hole tool?, Did you attach a center point when using the hole tool? Or did you cut holes from circles?
#3 Posted : Friday, January 19, 2018 4:17:20 PM(UTC)
You just select the hole (make sure the curser is over the inner wall of the hole for example) and the bar at the top should show its position, size etc. If you right click it in entities there's a 'move feature' and there you can move it. Fairly certain it works with holes.
Or hold ctrl when placing the hole and it'll give you a centre point. This can be moved by selecting the point and moving.
