Wow that are a lot of comments on my question. Love to see so much people using this program and willing to help others :)
The strange thing about the whole thing is that when i've used it the first time, everything went just well (See first.png picture). The problems began when i wanted to change some measurements and did a total redraw on the object. For some reason now i cant seem to get it working again.
The example file i've added with the last post was off-coarse just a simplified test. Not going to loft such a solid with a cube :) Lofting that same cube with the other solid seemed to work just fine so i concentrated on that other part what was in the example.
I've tried my original design again (See new.png picture) and matched the number of vertices of both objects i wanted to loft. But no result. I even checked the extruded solid for errors and although it had some (Strange as it was just generated out of a outline) i wasn't helping the lofting problem. See NewError.png picture.
Murray, How did you create a surface from that solid and then turn it back to a solid again? I've tried to create a surface from that solid but i don't seem to manage to creating a solid again from that surface?
I've added a new example vcp file including the both outlines from where the solids where created. I left in the error on the right solid so you maybe can see the difference with the left one. For some reason the left outline isn't generating a solid with errors while the right one does.
I guess something is wrong with the right outline but i can't figure out what ?!?!?!
Thanks in advance.
Edited by user Wednesday, February 14, 2018 5:12:35 AM(UTC)
| Reason: Wrong filename described
Error_test_2.vcp
(117kb) downloaded 2 time(s).WORP3 attached the following image(s):
(85kb) downloaded 0 time(s).
(37kb) downloaded 0 time(s).
(50kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
