la mouche
#1 Posted : Tuesday, October 13, 2009 7:19:53 AM(UTC)
la mouche
Here is a trick to create complex blend on your surfaces!
1-create an object surface mode
2-convert these surfaces to solid with "stitch" tool with option "closed volume required" unchecked.
3-you can create your blend with the blend volume tool on your surfaces!!:eek::)
4-convert the solid ==> surface
Result: you could create your blend surfaces with the blend volume tool.
Hybrid modeling, the best!
Thanks Tim :)
Antoine
Image 2.jpg (41kb) downloaded 5 time(s).
Image 3.jpg (33kb) downloaded 5 time(s).
Image 4.jpg (28kb) downloaded 5 time(s).
Image 6.jpg (36kb) downloaded 5 time(s).
#2 Posted : Tuesday, October 13, 2009 9:37:12 AM(UTC)
that one can be very useful - effectively allowing you to use the solid blend tool on surfaces ! ..
Good work Antoine !
