Art Smith
#1 Posted : Wednesday, February 7, 2018 12:12:37 PM(UTC)
Art Smith
Attempting to Use the “Modify/Advanced Transform/Assembly/Insert Face
Tool for Alignment/Installation, I Get an Illegal Alignment Face Error. Both
Faces are 0.500” OD/ID Circular Flat Faces..…… Any Ideas What I’m Doing
Wrong or SharkCAD Pro is Squawking About?? see attached image
thanks!
Art
artesmith@earthlink.net
assembly - insert face question.jpg (46kb) downloaded 8 time(s).
horst.w
#2 Posted : Wednesday, February 7, 2018 4:58:37 PM(UTC)
horst.w
This was current topic when I started with V 9 and I thought the issue is solved. Perhaps they had bring it back, when the Magnet-Function was implemented.
And this is also the makeshift in two steps to reach the same:
With the Magnet function you can bring down the head of a bolt to one level of the bloc where the hole is - but centered to the surface of the bloc;
2nd step, activate the gripper setting "User Positioned" and there check on the "Face Snapping"-option.
Positioning the bolt to the hole, it will be jumped to the center position of the hole.
horst.w
GER
(the 1st pic shows the bolt a little bit pulled up for better seeing)
The same effect as the Magnet is the Mate Face -tool, it holds the shank of the bolt on its position
Edited by user Wednesday, February 7, 2018 5:25:50 PM(UTC)  | Reason: Not specified
Bolzen setzen.png (48kb) downloaded 0 time(s).
Mate Faces.png (61kb) downloaded 0 time(s).
thanks 1 user thanked horst.w for this useful post.
Art Smith on 2/7/2018(UTC)
#3 Posted : Wednesday, February 7, 2018 5:30:09 PM(UTC)
I was doing just this earlier! The above is good, but I was trying to do it without using translate. I wanted to keep it "translate free". One of the mating types basically is weird and I couldn't get it to work right, it flipped the part the wrong way, moaned about things not being the same type of face, when they were, or at least I thought 2 flat faces were the same!
So I ended up using the method mentioned, works well!
horst.w
#4 Posted : Friday, February 9, 2018 4:11:55 PM(UTC)
horst.w
Hi together,
at the moment I would use the Snap Function so I described before, but it doesn't works .... gggrrrrrr
The face snapping function is offert for the User-Positioned option and I'm likely sure that I used it before.
Ok, changed to Gripper Center Selected and check ON the option there - and it works.
I have no idea what is the difference to my tries before, it is definitifly the same: a bloc with a hole and a headed bolt.
The only thing I can imagine is that the gripper was haphazardly positioned like Center of the Selected.
I'm really sorry for any confusion I may have caused but I'm assume myself innocence.
Horst
horst.w
#5 Posted : Friday, February 9, 2018 6:11:00 PM(UTC)
horst.w
I have tried out when the Snap is active.
Have a look to the pictures,
to activate the snap, the bolt must overlap more than a radius of the hole. Than the brink of the hole becomes red and when terminating the movement by a mouse click the bolt jumps centralised into the hole.
I hope, this is now the definitive solution ;-)
H.
