Dyn_Metalworks
#1 Posted : Saturday, April 21, 2018 12:17:54 PM(UTC)
Dyn_Metalworks
I currently have VC 2D/3D V9. If I upgrade to V10 or Pro can I transfer my custom toolbars?
#2 Posted : Sunday, April 22, 2018 6:51:16 AM(UTC)
Was thanked: 196 time(s) in 138 post(s)
1. Install The new Program
2. Go to the folder: C:\Users\yourusername\AppData\Local\Punch!\
3. Copy the config files from the Folder for VC9 to the Folder for VC10.
Maybe this works only after you have already changed some settings in the fresh installation. But it should work. I moved the settings also between Shark Cad and Shark Cad Pro, but when making this is a renaming of some config files necessary.
Edited by user Sunday, April 22, 2018 6:52:28 AM(UTC)  | Reason: Not specified
#3 Posted : Sunday, April 22, 2018 1:02:21 PM(UTC)
Try copying:
VC3Prefs.ini to VCPPrefs.ini
VC3Dialogs.ini to VCPDialogs.ini
if you have shortcuts...
VC3Shortcuts.ini to VCPShortcuts.ini
PRP
#4 Posted : Monday, July 15, 2019 10:49:10 AM(UTC)
PRP
Where are custom tool pallets stored in Mac?
rokoko
#5 Posted : Tuesday, July 16, 2019 12:46:28 PM(UTC)
rokoko
see here:
/Users/xxxxxxx/Library/Application Support/com.encore.viacadprov10esd/PalletPos.sys
PRP
#6 Posted : Thursday, July 18, 2019 1:49:05 PM(UTC)
PRP
Rokoko,
Thanks!
But "PalletPos.sys" seems to be a Windows 10 file or folder.
I'd try copying it to ...Library/Application Support/com.encore.viacadprov11esd if that existed.
Any ideas as to where VCPro11 Application Support would be?
